Old Aristocrat stuck arm
Re: Old Aristocrat stuck arm
Postby oliver4116 » Sun Nov 29, 2015 8:47 pm
Very nearly there but there are two problems that i cant seem to get over (maybe its just me) the video shows that when the mech is back inside the cabinet, the arm does not go down enough to push down the white roller and cycle it, dont know what i am doing wrong there, as vid shows i push down manually and can cycle it. It does push the coin in to coin spinner when done manually, i did it a few times
The other big problem is that when it cycles the reels dont move, the video shows that as well
https://youtu.be/xiEW6c6TrbI
So close but so far
oliver4116
Postby oliver4116 » Mon Nov 30, 2015 2:38 am
Well more good news, the arm started to move properly and i did it like 20 times in a row, the coin went were is was supposed to go, all good but
just 1 problem when you watch this video see i put the 10 cent in pulled the handle all that worked but reels did not spin
https://youtu.be/xZLh4p1wKAQ
My last problem for this machine
oliver4116
Postby mechanic » Mon Nov 30, 2015 5:07 pm
Oliver Good Going almost done!! Remove the frame around the reels and watch the kicker head located between the escalator and the reel plates. The kicker latches onto the serated edges and pulls down on them spinning the reels. May be a broken spring or needs lubing on the kicker head pivot. From the video looks like the kicker head is not grabbing the reel plates. Jim
Users browsing this forum: No registered users and 35 guests
