by oldslotman » Sun Jun 26, 2016 8:17 am
If it gets too hard the pull, I would suggest that you remove that anti cheat device in the front of the slides because it may cause the reels to spin at a very fast pace since it would holding back some of the action of the machine and put undue stress on it and may at some time in the future bend the payout slides push bar or cause the payout slide push bar spring to break. If you don't play the machine a lot it should not be a problem left as is, but if the machine gets used a lot you could a have a problem in the future. JMHO
