QT Check Pusher blocking off coin advance
Postby Lambow » Fri Oct 21, 2016 4:27 pm
I have nickle mills qt that will not cycle. On inspection it appears that the Check Pusher is blocking off the coin from entering the check detection pocket. If I push the Pusher a 1/8 of an inch higher with my finger the coin drops right to the pocket. There is a weak spring might be the cause of the Pusher not retracting up enough, but pulling on that spring giving to more tension doesn't seem to make any difference. All the other coin checks seem to be working correctly. Has anyone had a similar problem and fix?
Thanks for any help
Lambow
Users browsing this forum: No registered users and 46 guests
