Buckley Cent a Pack
Buckley Cent a Pack
Postby Myhorses » Thu Nov 30, 2017 5:25 pm
I recently purchased a Buckley Cent a Pack trade stimulator that was represented to have been exposed to smoke, but does not appear to have been exposed to excessive heat. I am new at working on these machines and am attempting to clean it and get it working properly. My questions are as follows:
1. How do I get the front panel out safely. This panel and the sides are fastened to the base with clips and I do not want to bend or break anything getting it out.
2. The windows for the reels and gumball display appear to be very thin laminated glass with severe occlusion between the sheets. What should I replace them with?
3. Looking at the reels from the backside, the left one rotates smoothly and then properly stops when the handle is released. The other two jiggle but do not advance.
I can manually rotate them, but they are very tight. Could this be an adjustment or lubrication problem?
Any suggestions you have would be greatly appreciated.
