Mills jackpot
Mills jackpot
Postby bosmod » Mon Dec 04, 2017 6:07 pm
Can someone tell me if the photos i attached are normal. The mechanism appears to be bent. If it is i will purchase new one
Don't want to spend money needlessly. Thanks for any help. It is part of the jackpot ass'y on a Mills high top special award 777. The jackpot paid out but the reserve didn't drop. The rear chute has a bad lever, it needs replacing as well. Someone tried to weld it back together. Binds up
bosmod
Re: Mills jackpot
Postby oldslotman » Mon Dec 04, 2017 6:19 pm
It is suppose to be bent. Looks like it maybe ok but hard to tell without seeing it mounted on the jackpot.
Re: Mills jackpot
Postby bosmod » Tue Dec 05, 2017 10:20 am
in the bottom photo, is the center suppose to be bent where the u shaped space is? the two ends go in opposite directions. that was one of my main concerns. i will have to upload another pic showing my other concern.
bosmod
Re: Mills jackpot
Postby oldslotman » Tue Dec 05, 2017 12:46 pm
Here it what it should look like on the jackpot.
