Mills High Top pays out too often
Postby cbvig » Tue Feb 06, 2018 12:30 pm
How do I keep my Mills from paying out too often? The tube runs out because of the frequent payouts.
Chris
Springfield, OR
cbvig
Re: Mills High Top pays out too often
Postby Imyourcaptain » Tue Feb 06, 2018 3:11 pm
Is your high top paying out correctly on winning combinations? Is the payout tube being filled as you play? Generally it takes 3/4 rolls of coins to get machine filled up. Once you put enough coins in it shouldn’t be running out
Randy
Imyourcaptain
Postby cbvig » Tue Feb 06, 2018 9:40 pm
Yes, I filled the tube and it does run out. Everything else works fine--all payouts and jackpot. It's just that it pays out so often that the tube empties eventually, even though coins do drop into the tube as you play.
Chris
cbvig
Postby oldslotman » Tue Feb 06, 2018 9:51 pm
Someone may have altered the payout dics. Are there any patches on the reel stripe. Patches, symbols placed over other symbols.
Postby oldslotman » Tue Feb 06, 2018 9:57 pm
If possible can you list the symbols on the three reel disc. It is possible that the wrong reel disc are installed.
Postby oldslotman » Tue Feb 06, 2018 10:15 pm
I'll bet it is paying on cherries quite often. If it is you may the wrong reel bundle in it.
Postby cbvig » Wed Feb 07, 2018 9:29 pm
Oldslotsman,
Do you mean the symbols for all three discs? Or just the one on the far right?
Chris
cbvig
Postby oldslotman » Wed Feb 07, 2018 9:53 pm
just the first reel strip. is your machine a 2/5 or 3/5 pay for cherries/
Postby cbvig » Thu Feb 08, 2018 9:55 am
It's a 2/5, if I understand you correctly.
cbvig
Postby oldslotman » Thu Feb 08, 2018 10:53 am
If you have a 3/5 reel bundle in a 2/5 machine it will payout on cherries like crazy. A 2/5 reel bundle only has like three cherries on the first reel. A 3/5 reel bundle will have like seven cherries on the first reel allowing for more payouts.
