Polishing castings
Polishing castings
Postby Nick » Sat Aug 04, 2018 1:15 pm
When I used to do a lot of restoration, I would take the castings and have them professionally blasted to a nice shiny surface. The place where I took them is no longer in business and I am not sure there is anyone else here that will do that.
Does anyone have a contact for someone that does this sort of work routinely?
Also, if I want to try and hand polish a little bit, what would you recommend that I use? Steel wool? Somthing else?
Thanks.
Nick
Nick
Re: Polishing castings
Postby Rick-okc » Mon Aug 13, 2018 6:58 am
Nick,
Blasting the castings should leave them with a dull or satin finish, depending on the blasting material used.
If I have a casting that is really dirty, I'll glass bead blast it with as light a pressure as I can use to get the casting clean.
Then I'll start with 220 grit sand paper and lightly sand the areas I want to bring to a high polish.
Next, I'll use a finer grit paper, then a finer grit paper, then a finer grit paper.
Then I'll use a buffing wheel to finally bring out the polished look I'm going for.
If you don't want to go through all that, then look around for a company that does bead blasting and one that does polishing.
If you have a plating business nearby, they can do the polishing.
Hope this helps.
If you're ever in the central Tennessee area, give me a yell.
Rick
Rick-okc
