Jennings J400 fuses
Jennings J400 fuses
Postby Nick » Wed Aug 29, 2018 8:35 am
I am having a problem with a Jennings J400 machine not accepting coins. They just fall right through. When I fliip the little wire that should activate the machine, nothing happens.
Somone told me to check the fuses in the cabinet.
Can anyone tell me where the fuses are? In looking around I don't see anything that looks like a typical fuse. I do see a few little silver barrel like components that look like fluorescent light starters.
Thanks.
Nick
Nick
Re: Jennings J400 fuses
Postby MONTI » Fri Aug 31, 2018 9:22 am
Pull out the hopper, there are three fuse holders, with a black cap, that will be to the high left of the power supply area!
But being a J400 Jennings you may also have Logic Board issues if you have other erratic operation!
Jennings Standard 400 Manual fuse location.pdf
(2.25 MiB) Downloaded 27 times
