Mills base repair/replace
Postby GR14 » Sat Mar 30, 2019 3:07 pm
Hello, I have a Mills Castle Front nickel slot machine that has been in the family for 70+ years. The front 3 or 4 inches of the base is missing. Are bases available, either used or repro? If I end up making one, are there any pitfalls? Thanks!
GR14
Re: Mills base repair/replace
Postby mechanic » Sat Mar 30, 2019 5:31 pm
A picture helps to determine if the base is repairable!
Postby GR14 » Sun Mar 31, 2019 10:24 am
GR14
Postby radiorich123 » Sun Mar 31, 2019 12:23 pm
It can be repaired no problem. You need to find aged wood that the base was made of so it matches the old one. Yours looks original from the photos.
Users browsing this forum: Google [Bot] and 15 guests
