Jennings Tic Tac Toe
Postby capt7310 » Wed Dec 12, 2018 1:27 pm
Hi, just picked up a nickel Tic Tac Toe and I'm not sure if it's working correctly. It has been sitting in a person back room for over 20 yrs not used so the grease is all dried up which I'll clean up and re grease, but I'm not sure if the reel backstop lever is working properly, there is no stop lever pushback bar, the reels spin OK and the payouts are correct. I don't know if this is the way this machine works, and I'm not sure if it has been worked on. Any help would be appreciated. One more question if there is a Tic Tac Toe in any combo it's pays 18 is that also correct.
capt7310
Re: Jennings Tic Tac Toe
Postby capt7310 » Sun Dec 16, 2018 5:15 pm
I found the answer..machine works perfect
capt7310
