Watling Blue Seal problem
Postby bajrbajr » Sun Dec 01, 2019 6:28 pm
I recently found a Watling Blue Seal that was missing the inner-frame for the reel window.
I found one, but it will not fit properly because of the black overflow tube that is over, and wraps around the jackpot fill chute.
The red part of the inner-reel frame hits this black tube which won't allow it to fit all the way on to the cabinet.
Is this a different version of the Blue Seal that has a different reel window frame?
I could grind a notch out of the red part of this window frame, but I hate to do that to good original part if there is a better solution.
Thanks in advance for the help!
bajrbajr
Re: Watling Blue Seal problem
Postby gsx11r » Mon Dec 02, 2019 1:20 pm
Hello Bajrbajr
You are right , don t touch the Windows frame .
There are a lot of blue seal version. Your is uncommon.
But your problem is that the black overflow tube is not at his place and I m not sure that is a Watling part also.
I know your model and this not the original cover.
Do you can make more photos ? As this , I will be able to help you.
I need photo from Inside , from the upper and photo of the mechanism .
And don t touch the frame !!
Stephane
gsx11r
