How hard to pull?
How hard to pull?
Postby d12bn » Sat Jul 22, 2017 3:36 pm
I finally bought my first slot machine after months of searching. It's a Mills high top Jewel. I'm surprised and a little disappointed in how hard it is to pull the handle. Can something be adjusted to make it easier? I think it's normal because the seller had 3 Mills Jewels and I tried all of them and they felt similar.
Vintage Vending Machine Discussions Repairs And Sales
https://www.facebook.com/groups/151347598650253/
d12bn
Re: How hard to pull?
Postby mechanic » Sat Jul 22, 2017 3:53 pm
There is a long spring on the mech with two hooks. The hooks are adjustable. Take the hook off the upper peg keeping the pork chop from moving down and see how far below the peg the top of the hook is from the bottom of the peg. It should be no more than 1/8" space between the bottom of the peg to the upper bend of the hook. If it is ove 1/8" then adjust the hook out till it closes the gap. Many times the previous owner / operator made the tension greater to correct a problem by causing another like the reset on the escalator would not work when the tension on the main spring was reduced. If this occurs when you adjust the spring then in most cases the tab along side the vertical finger reset needs to be lubed and or adjusted to allow the pork chop to be released which also then allows the escalator to reset. Try it and see what happens. You can always put it back the way it was.
Postby d12bn » Sat Jul 22, 2017 5:41 pm
Thanks for the info. Is this the spring?
mechanic wrote:There is a long spring on the mech with two hooks. The hooks are adjustable. Take the hook off the upper peg keeping the pork chop from moving down and see how far below the peg the top of the hook is from the bottom of the peg. It should be no more than 1/8" space between the bottom of the peg to the upper bend of the hook. If it is ove 1/8" then adjust the hook out till it closes the gap. Many times the previous owner / operator made the tension greater to correct a problem by causing another like the reset on the escalator would not work when the tension on the main spring was reduced. If this occurs when you adjust the spring then in most cases the tab along side the vertical finger reset needs to be lubed and or adjusted to allow the pork chop to be released which also then allows the escalator to reset. Try it and see what happens. You can always put it back the way it was.
d12bn
Postby mechanic » Sun Jul 23, 2017 7:13 pm
NO. It's on the handle side of the mech.
Postby Mechanik » Tue Aug 01, 2017 5:51 pm
My Pace is the same way and I'm guessing that it's probably normal for a big mechanical. If you take the mechanism out of the case and ratchet the pull lever through the stops, you can see that the pull is resisted at every step by a lot of very heavy springs. All these mechanisms are preloaded with the energy of your pull against the springs and then latched in place so that all that potential energy can be released in sequence when you reach the bottom of the pull. Amazing!
My Pace is a few years newer than your Mills, but the mechanism is similar.
Mine is also very noisy as it cycles. Anyway mine's been in use for maybe 60 years so it was probably built to take it.
Mechanik
Postby d12bn » Mon Aug 07, 2017 9:16 am
Thanks for your comments
Mechanik wrote:My Pace is the same way and I'm guessing that it's probably normal for a big mechanical. If you take the mechanism out of the case and ratchet the pull lever through the stops, you can see that the pull is resisted at every step by a lot of very heavy springs. All these mechanisms are preloaded with the energy of your pull against the springs and then latched in place so that all that potential energy can be released in sequence when you reach the bottom of the pull. Amazing!
d12bn
Users browsing this forum: No registered users and 20 guests
