I need parts for Mills goose neck
Postby Docmuskie » Thu Nov 02, 2017 5:38 pm
I need to find a few parts for a Mills goose neck machine that has been in my family for years. I have played with it for nearly 60 yrs. I'm not sure of the year it was made or model, the serial number seems to be 146312 If that helps someone to tell me. It seems to work pretty well. There is a plate behind the goose neck coin slot is missing. And the paper panel on the front that pictures payouts is torn. Lock is gone. Please tell me the best way to post my needs on your forum. It is likely I will need to post photos of what I need. Thank you.
Emil
Docmuskie
Re: I need parts for Mills goose neck
Postby radiorich123 » Thu Nov 02, 2017 6:31 pm
HI
I have the mills lock and key for your back door original $95.00 or a repro $20.00 shipping is $6.00
Regards
RICHARD
Postby Docmuskie » Thu Nov 02, 2017 7:51 pm
Sounds good. Thank you. The repro will probably do. I need to refinish the cabinet so it won't be original anyway. Is there a way I can send you a picture of the missing lock area to be sure it would drop right in?
Docmuskie
Postby radiorich123 » Fri Nov 03, 2017 5:59 am
HI
Email photo at
