Rol-A-Top Coin Front top casting
Postby wahsah » Sun Apr 01, 2018 9:35 am
There are two versions (that I have seen) of the coin front top casting. On one version, which is also seen on the Rol-A-Tor, the coin front casting has a liberty head coin at the top, closest to the mouth of the horn of plenty.
Liberty coin
On other models, at that same coin position, the coin is a shield, similar to the reverse of the 1868 US nickel.
Shield Coin
Does anyone know if there was a reason for the change, or when exactly they used each of the variations :?:
Thanks much
wahsah
Re: Rol-A-Top Coin Front top casting
Postby radiorich123 » Sun Apr 01, 2018 9:40 am
HI
The lower photo shows the foreign coins probably made for the over seas market.
Postby saloonkpr » Sun Apr 01, 2018 2:56 pm
Both for American Market...Treasury Dept. Told Watling ILLEGAL to USE AMERICAN COIN...Bottom Model a Later Model
saloonkpr
Postby wahsah » Sun Apr 01, 2018 3:21 pm
In the U.S patent application filed by Thomas Watling on Sept. 21, 1934, for a 'HEAD OF COIN CONTROLLED MACHINE CASING", the patent drawing shows the liberty head coin.
Thanks, saloonkpr.
Do you know when they made the switch?
wahsah
Postby saloonkpr » Mon Apr 02, 2018 2:12 pm
Late 1935 Caille Changed to Non US Coin
saloonkpr
