Mills Castle Front
Mills Castle Front
Postby capt7310 » Fri Aug 03, 2018 12:03 pm
Looking for a little help. Just bought a Mills Castle Front and the 5 escalator wasn't returning back all the time after the nickel was put in. So I knew it was just a little dirty and gummed up so I removed it to clean and re lube. When I removed the escalator from the casting this metal piece fell out. It's been like a jigsaw puzzle I can't seem to see where and how it gets attached. Any help would be great. Thanks
capt7310
Re: Mills Castle Front
Postby mechanic » Fri Aug 03, 2018 3:45 pm
This fits over the lower left corner of the escalator under the magnet and on the outside. To reinstall the piece you need to remove the escalator from the top casting then reattach the cover and put the escalator back on the top casting.
Postby capt7310 » Fri Aug 03, 2018 4:31 pm
Thanks for your help but anyway possible of a photo. Looking at the escalator where the coins come down into the sensor pin right under that location? Does the plate connect to the escalator or to the casting, I just can't seem to locate it's position
capt7310
Postby capt7310 » Sat Aug 04, 2018 10:21 am
Think I got it. It's the bracket for the coin reject into the slug cup. Posted a pic for someone in the future if they come across this same situation
capt7310
Postby mechanic » Sat Aug 04, 2018 8:49 pm
YUP You got it !! CONGRATS!!
Postby capt7310 » Sun Aug 05, 2018 3:29 am
Thank you for your help. Great site I'm glad I found.
capt7310
Postby mikesoldtoys » Wed Nov 14, 2018 8:51 pm
mikesoldtoys
