HELP .... Slides won’t move when payout is required
Postby Jaysrestoration » Wed Aug 15, 2018 4:57 am
Ive just finished a full clean of a jubilee Ace bonus 3 reel and when testing the mechanism every time it lands on a payout the slides won’t move to make the payout. I’ve not done them up to right there free from dirt,grease etc , the springs are not to loose, it seems like when the pay fingers go into the pay holes on the reels and are ment to push the slide fingers back to allow the slides to move back to pay there not hitting the slide fingers hard enough to move them back has anyone please got anything I can try I need this machine working ASAP. Thank you
Jaysrestoration
Re: HELP .... Slides won’t move when payout is required
Postby oldslotman » Wed Aug 15, 2018 1:40 pm
Replace or shorten the springs on the vertical fingers. Also make sure the payout slides are being reset and not resting on the payout levers. Make sure you have the fifth click.
Postby Jaysrestoration » Wed Aug 15, 2018 4:03 pm
Hi Oldslotman I sent you a private message but thank you.
Jaysrestoration
