Slot machine furniture pads
Postby fazool » Wed Oct 24, 2018 11:16 am
Hi All, Anyone know of a source for antique slot machine protective pads for putting slots on top of furniture?
Thanks in advance for your time!!
Jon
fazool
Re: Slot machine furniture pads
Postby capt7310 » Wed Oct 24, 2018 12:36 pm
Hi Jon, don't know if this helps but this is what I use on the bottom of my machines that go on top of my wood tables tops. Works perfect and simple to install and remove. Just a thought.
X-PROTECTOR Premium ULTRA LARGE Pack Felt Furniture Pads 181 piece! Felt Pads Furniture Feet ALL SIZES – Your Best Wood Floor Protectors. There at Amazon or Costco less than 15 bucks
capt7310
Postby fazool » Thu Oct 25, 2018 1:18 pm
Many thanks!!!!!!!!
fazool
Postby Rick B » Fri Oct 26, 2018 5:34 pm
I buy the large pads at Home Depot and cut to fit the sleds underneath. Rick B
Rick B
Postby fazool » Fri Nov 09, 2018 3:29 pm
Thanks!!!!!
fazool
Postby mechanic » Fri Nov 09, 2018 5:26 pm
I use the pads that woodworking shops use for anti skidding. Secret is they are the same as padding for carpet installation, the multi colored stuff.
Postby mrslot1 » Sat Nov 10, 2018 6:21 am
Just wanted to add my 2c of info here
My Father (Bernie) used to sell slot pads many years ago, but however, certain poly urethane's these days caused a chemical reaction and the pads were melting to the oak!
So for obvious reasons we stopped selling them,
I remember the Slot pads Tom K. used to sell were typewriter pads, a little more pricey, but they do the job too!
thanks guys
mrslot1
Postby Rick B » Sat Nov 10, 2018 8:15 am
I make the skids incase anyone needs them. I have 13" & 14" at the moment. Can make to any size. Rick B
Rick B
Postby neocoinops » Mon Nov 12, 2018 10:15 am
I found that non-slip shelf liner works well instead of felt pads, since the machines tend to slide on felt. This is easily cut to the size you need.
https://www.amazon.com/Liner-Non-Adhesive-Shelf-Anti-Slip-Drawer/dp/B079MLC7C6/ref=sr_1_5?ie=UTF8&qid=1542042540&sr=8-5&keywords=non-slip%2Bnetting&th=1
neocoinops
Users browsing this forum: damikeguy and 3 guests
