by berardini21 » Mon Jan 16, 2017 4:07 pm
Ok, jackpot area was filled with tissues to stop it from filling up, there was a broken spring inside a fairly large spring I believe it has to do with the arm mechanism, counter is not working. Fixed the not paying out on the oranges, part of the counter was in the way. Coins are not going into slug tray, they are cycling correct. I could be wrong but don't these things spit out a token when you hit the jackpot ? I'm trying to find where it would be ? Thanks in advanced
