Mills Casting Numbers
Postby Uthguy737 » Mon Jan 29, 2018 9:13 pm
I was looking for some information on a machine that I inherited from a neighbor recently. What I’ve gathered so far is that it is a Mills Black Cherry Nickel Slot Machine. There are a couple casting numbers on the inside that I was hoping you fine people could tell me about. The numbers are MLB7423 and MLB7414. Thank you for any information you could give me about these numbers. Are the original Mills Parts for this machine or are they reproduction parts that have been swapped in at some point. Thank you for your help!
Uthguy737
Re: Mills Casting Numbers
Postby oldslotman » Mon Jan 29, 2018 10:47 pm
MLB 7414 should be on the lower front casting. MLB 7413 should be on the upper front casting. MLB7423 ???
Postby Uthguy737 » Tue Jan 30, 2018 11:29 am
Sorry, fat fingered the first number...it should read MLB7413
Uthguy737
Postby oldslotman » Tue Jan 30, 2018 11:55 am
They are the correct castings.
Users browsing this forum: No registered users and 57 guests
