mills vest pocket
mills vest pocket
Postby midohioslotmachines1 » Fri Mar 16, 2018 5:55 am
On the Mills Vest Pocket, the little lever pull that you put the coin in is stuck and will not come out.
when we opened the back door we noticed that some penny's were in there and there may be one stuck.
This is a nickel machine. Any help would be appreciated
Re: mills vest pocket
Postby mechanic » Fri Mar 16, 2018 11:16 am
Two possible ways to release. First is the little ratchet where the serrated side of the slide is you will need a fine flat blade screw driver and carefully release the dog so the slide can move. Second is the heavy chromed lock that has the tension spring on it top of the slide . same idea carefully move the lock up until the slide releases. Be sure all coins are out of the way.
