Nick wrote:Actually, I found an old can of the paint I used to use on restoration of the castings of slots. It was Red Devil Polyurethane paint. It came in a variety of really nice, bright colors. It came in small cans so that you did not have to buy a quart or more of it. Apparently this brand is no longer available. Does anyone have a suggestion of a similar paint that might be available in smaller quantities thatn a quart? What do other people use for painting castings?
Is the comment about auto paint something to pursue?
Nick
I remember those old small cans that places like hardware stores used to carry. Some may still be available if you look online.
There was discussion about paints a couple of years ago here:
http://www.coinopcollectorforum.com/viewtopic.php?f=6&t=3421As mentioned there, this shows all the colors of Testor's paint, with the implication that they're mostly or all available in larger 3 oz sizes and spray cans:
https://www.testors.com/product-catalog/testors-brands/testors/enamel-paint/enamel-paintsThose would be good for colors in the ballpark of the sort of popular period colors used on automobiles - and with luck, a pretty exact match for some - or at least good enough for spot work like details and touch-ups. Speaking of touch-ups, I'm going to have to go to Hobby Lobby and see how well the colors available match those on Vest Pocket award flaps. Plus with the little Testor's bottles, it would be easy enough to experiment with a bit of mixing to match exact colors, and even throw it out and start over if it went wrong. I haven't tried it with paints, but I buy packages of plastic syringes and use them for precise and repeatable measuring for other sorts of mixing.
For a really good match, especially to an old sample, there may not be anything like custom-mixed automotive paint to match the characteristics of the paint they used on old slots. Sherwin Williams can make about any color in their house paint deck as a gloss oil-based enamel, mostly available in quart size though a few colors may have to be made up by the gallon; that's going to have to do for me, unless I'm really dissatisfied with how the major color I'm using turns out.
Also, I got some of the high-heat silver paint that's fairly matte, to try to match the color (and durability) of whatever Mills used on metal parts. I can see that even the studs of the bolts that hold the award flap on the VP, originally had that sort of paint on them. I see that for old radiators, there's also what looks to be an old-fashioned formula paint available with aluminum dust content.
