Mills 1915 Operators Bell/Spearmint parts needed
Postby jmisatu » Fri Jan 09, 2026 10:41 am
I am in need of a decently working clock for a 1915 Mills Spearmint/Operators Bell Slot machiune. At the least, I could use just the bottom plate but the main gear/bull gear bottom shaft bushing would need to accept a 7/32" diameter shaft. Thank you in advance for any help with this.
jmisatu
Re: Mills 1915 Operators Bell/Spearmint parts needed
Postby jmisatu » Mon Jan 12, 2026 7:54 am
62 views and not one person with any help or suggestions?
jmisatu
Postby Blofish » Mon Jan 12, 2026 8:25 am
I feel your pain, I have unanswered questions as well with 3,000 plus views and no answers. :|
Blofish
Postby mechanic » Wed Jan 14, 2026 2:04 pm
IS THE CLOCK BULLGEAR STRIPPED? MOST OF THE REAL OLD STUFF NEEDS NEW BEARINGS INSTALLED DUE TO WEAR. GEARS CAN BE WORN TOO. LET ME KNOW WHAT YOU HAVE. LATER JIM
