Watling Slot Clock Part Needed
Postby drsmlojo1 » Sun May 03, 2026 11:50 am
Hi everyone: I have a Watling Antique Bird of Paradise Slot and need the Secondary Fiber Gear that is in the clock mechanism. Mine is worn out and fan blade can't spin. I believe a Blue Seal also used this part. Thanks so much!! Steve L. (909)630-3450
drsmlojo1
Re: Watling Slot Clock Part Needed
Postby mechanic » Mon May 11, 2026 4:58 pm
WHATS THE DIAMETER OF THE TOOTHED GEAR. I HAVE BOTH DRIVE AND FAN GEARS MADE OF BRASS NOT FIBERBOARD!!
