NOVOMAT 50's Mech Payout
Have a NOVOMAT - Gunther Wulff - german made mechanical English slot PENNY machine.
It is in a refurbishment stage and in need of the pretty much the entire cast metal "Mech Payout" assembly located at the bottom of the coin tubes.
(In the attached pic, this assembly would be attached at bottom of brass looking coin tubes lower left of over-all Mechanical Assembly as a whole.)
I believe it consists of a Top Plate Assembly / 4 individual coin plates / Bottom Plate Assembly and associated springs and pins in order to connect & attach all.
Also, if anyone can tell WHICH model this Novomat might be, that would be most helpful too. I received this missing a lot of the tell-tale bits on the front. There was a Novomat german oiling & maintenance placard on the interior. That was it.
So, should anyone have any of these parts or information to locate them, I would greatly appreciate it. Trying to locate these machines, let alone parts for them here in the US in proving very difficult.
Thank you for any assistance.
