Looking for parts
Looking for parts
Postby 240jetpower » Thu Mar 21, 2013 11:37 am
I am looking for the top casting for an early 20s Mills Operators Bell, I believe that it had the word SPEARMINT cast in it just below the coin viewing window. The casting I am looking for is aluminum. Thanks :)
240jetpower
Re: Looking for parts
Postby SLOT DYNASTY » Thu Mar 21, 2013 4:00 pm
240jetpower wrote:I am looking for the top casting for an early 20s Mills Operators Bell, I believe that it had the word SPEARMINT cast in it just below the coin viewing window :)
Mills made this model in both Cast Iron, and Aluminum, so it should be specified as to which one you need.
Postby andydotp » Fri Mar 22, 2013 12:05 am
And if anyone has a 1914 Cast Iron Mills Operators Bell lower front casting without cracks or repairs please let me know, a pittance will be offered immediately.... :wink:
Thanks.
andydotp
Sadly there's a (very well) repaired slight crack just left of the bell and some previous owner sprayed the casting silvery. Otherwise gorgeous.
Oh, press ctrl- for the bigger pic...??
andydotp
