Mills QT
Mills QT
Postby vndgguy » Fri Jun 06, 2014 8:26 am
I'm looking for a few parts for a penny Mills QT Chevron. I need a check pusher with mounting screw, right side check pusher security plate, check drop control lever, check diverter chute, and the 4 spacer bushings for the jackpot glass. All 3 pieces of glass are made up of 2 thin pieces. Anyone know the thickness of the original glass ? I could probably source the screw,spacers and glass if anyone has the dimensions. I'm also having trouble getting coins to fill the left jackpot. Occasionally a coin will make it to the jackpot, but most fall just short and go to the cashbox. The right side fills fine. Any & all help is appreciated.
Don
vndgguy
