Delux Mercury 1cent Machine
Postby Cfroadhog » Sun Dec 27, 2020 10:48 am
I posted in arcade a repair question re the above machine. I am adding a photo of the machine. And ideas as how to fix? On the internal mechanism the lever that the bottom screw driver pointed to can be pulled down manually to make it work. Is there a spring missing to make it work? The top screwdriver points to a brass nub, what goes there? Any help will be appreciated
Cfroadhog
Re: Delux Mercury 1cent Machine
Postby integ194 » Sun Dec 27, 2020 2:26 pm
This is a pic of a Liberty mech which appears to have a similar mechanism. you will note the spring between your screwdriver pointers.
integ194
Postby Cfroadhog » Mon Dec 28, 2020 3:47 pm
Got it working without that spring would it be possible for you to take a picture of the front mechanism and the back it all seems to work now
Cfroadhog
Postby integ194 » Mon Dec 28, 2020 7:10 pm
That was a pic I got from Ebay some time ago. You should be able to get the pic you want from completed listings.
integ194
