Jennings Chief Tic Tac Toe Jackpot
Postby Phan000 » Thu Oct 22, 2020 9:55 am
Greetings,
I just got my first mechanical. Pretty familiar with EM slots and modern reels.
It is a Jennings Chief "tic tac toe" dime machine. It currently plays pretty well, just needs some cleaning.
The jackpot does not seem to be functioning. When I trigger a jackpot, only the furthest pin engages into the reels, and 10 dimes are released.
I don't really understand what is supposed to happen, but would love some help sorting this issue out.
Thanks in advance!
Phan000
Re: Jennings Chief Tic Tac Toe Jackpot
Postby radiorich123 » Thu Oct 22, 2020 12:48 pm
You should get the jennings slot repair book. Look on the internet.
Rich
Postby oldslotman » Thu Oct 22, 2020 3:34 pm
Did the jackpot open?
Postby Phan000 » Thu Oct 22, 2020 4:14 pm
I will be purchasing the book... in the meantime, I do want to fiddle a bit to see how it operates.
The jackpot did not open. The top slide extended, but it looks like the linkage needs adjustment or possibly is missing a piece.
https://i.imgur.com/PpdkUwh.jpg
https://i.imgur.com/eRnqBtU.jpg
https://i.imgur.com/F24s8JD.jpg
Phan000
Postby oldslotman » Thu Oct 22, 2020 10:04 pm
Jackpot is not put together right.
Postby Phan000 » Fri Oct 23, 2020 4:48 am
I think that I got the levers aligned correctly now, but jackpot is still not opening. Is the slide supposed to come out and push the lever going up? Is there a spring missing on the outside of that lever?
Phan000
Postby oldslotman » Fri Oct 23, 2020 9:08 am
The slide goes back and the lever goes down.
Postby oldslotman » Fri Oct 23, 2020 9:17 am
Postby Phan000 » Fri Oct 23, 2020 9:45 am
Thanks for the input.
So to clarify, there is not a spring that should connect the post with the yellow arrow to the reset lever underneath?
I
Phan000
Postby Phan000 » Fri Oct 23, 2020 9:52 am
In this photo I got from a video, it appears there is a spring there
Phan000
