Castle Gold Award resto
Re: Castle Gold Award resto
Postby MTB » Sat Nov 26, 2016 5:20 am
mechanic wrote:You should be able to get the parts from Dave Berten. The gold award strips need to be put on also. Check the disks, they should have a notch just below the point so the backspin lever goes in further than normal to engage the trip on the vendor. If you do not have the notch you may have to change the disks.
Thanks for that info. -very help full. Matt
MTB
Postby MTB » Sat Nov 26, 2016 5:22 am
oldslotman wrote:It appears that you are missing all of the linkage needed to get the gold award to work. And based on the color of the reel they appear to newer and most likely not the ones for the gold award to work. It is possible to maybe everything that you need but it may take some time and money. You can alway paint the glass that shows the gold award tokens the same color as your machine to make it look like part of the castings. The two parts that you have are from the esculator. I do not have a machine at this time with the gold award but maybe someone else can posts some pictures of one working and the parts you are missing.
Thanks for that info. Matt
MTB
