Could it be wrong strips?
thanks
captkid wrote:Check the slides are they Dirty?
Are all the slides resetting in the forward position on each play and holding in the forward position- if not
Check the horizontal fingers - dirty? Or sticking allowing the slides to release
With odd payouts
Check the horizontal finger springs - weak ,missing
Horizontal fingers must have spring tension to return them to the left to hold the slides
Last would be the vertical fingers but I think it's one of the above
oldslotman wrote:Slides have to be removed from the machine to clean. DO NOT lube them. No oil or grease. Where are you located? Maybe someone of the forum lives close by and can help you.
d12bn wrote:Can someone explain how the machine knows when to pay 3 coins or 5. What the fingers do and what the slides do ?
I don't understand how sticky slides could cause paying more however I don't understand how the machine works. Thanks
