Ballys Quarters (new to me)
Re: Ballys Quarters (new to me)
Postby 63mini » Sun Feb 04, 2024 7:56 am
John,
You are correct. Mechanical meter is a standard EM machine. LED would be an E-series machine or possibly a Summit conversion. But appearance wise yours does not look like a Summit.
Lastly, I believe your machine is a 1090.
63mini
Postby john@alaskajohn.com » Sun Feb 04, 2024 8:20 am
Awesome info. Thanks.
63mini wrote:You will find on NLG most of the guys like to go the lock pick route as we like the challenge.... :D If you post a photo of the lock, we can tell you if it's an easy one or not.[*]
Lock closeup
john@alaskajohn.com
Postby john@alaskajohn.com » Sun Feb 04, 2024 8:37 am
63mini wrote:You are correct. Mechanical meter is a standard EM machine. ... Lastly, I believe your machine is a 1090.
Thank you!
john@alaskajohn.com
Postby 63mini » Sun Feb 04, 2024 8:39 am
John,
That's an easy one. You can drill it. Just be certain to have a good "center" point to start. If you like the challenge. Below is an image of the picks we use for tubular locks. They are pretty cheap and easy to use.
63mini
Postby john@alaskajohn.com » Sun Feb 04, 2024 10:20 am
I am excited to get started so I went ahead and drilled it.
With the door open there are clearly issues including disconnected wires and the graphics have been repaired with tape at some point.. as well as other signs of previous repairs.
I will start with the most obvious stuff.
Thanks!
john@alaskajohn.com
Postby shortrackskater » Sun Feb 04, 2024 10:24 am
Pick the lock! It's EASY... Youtube and Amazon are your friends, well most of the time.
It looks like you registered successfully. Most issues are right at the start, with our TOS page and the "accept" at the bottom.
Post in Bally EM and you'll get a flood of responses from member Wolftalk, DavidLee, and the rest of the EM gang.
https://newlifegames.com/nlg/index.php?board=77.0
shortrackskater
