Williams Stampede Power Supply
Postby leospanner » Mon Sep 23, 2024 10:49 am
Hello everyone... I'm looking for a lower/bottom power supply for a 1996 Williams 400 Stampede slot machine. It was diagnosed by New Life Games as needing a power supply but they didn't have one so I'm out looking. I've sent a few emails out, but still no response. Thanks in advance for anyone that can help me find one. Sending the best out to all you coin oppers. Leo...
leospanner
Re: Williams Stampede Power Supply
Postby ThirdGenAmusement » Mon Sep 23, 2024 11:15 am
You can use a switching power supply meant for a PC to replace the original. There will need to be modifications needed to splice into the factory harness and the original power supply completely disconnected. If your handy, you can probably go the modification.
ThirdGenAmusement
Postby radiorich123 » Mon Sep 23, 2024 2:20 pm
I have power supply need the voltage and amps of your old one.
Postby tsparts4u » Mon Sep 23, 2024 5:42 pm
Hi Leo,
I have found Heather Chism and her husband, extremely helpful with problems on my Williams Dot Matrix slot machines.
If they can't help you, I am pretty sure that you are looking for a needle in the haystack.
Best of luck. Give them a shout at terpsmd@gmail.com
Regards,
Jerry (tsparts4u)
tsparts4u
