Jennings slot machine
PostPosted: Wed Feb 05, 2025 10:51 am
by midohioslotmachines
The machine is on free play, can not see where a coin jam is,. if I put pressure on the chain it will take the nickel and play, then it goes back into free play, can anyone help with this?okay, there is no coin jam, need to know where the screw is to tighten the chain, too much slack in chain
Re: Jennings slot machine
PostPosted: Sat Feb 08, 2025 2:32 pm
by mazzeosa17
you can loosen or tighten the chain via the bracket on the left escalator chain sprocket (that is left, looking from the back of the mechanism). See attached photo with two bolts holding bracket in place.
PostPosted: Wed Feb 12, 2025 7:13 pm
Thank you so much, will look and get back with you. Again thanks
