Jennings Silver Chief 25¢ – Higher Payouts All One Quarter S
Postby Mully911$ » Sat Aug 29, 2026 8:10 am
Hello all,
Thanks for letting me join into all the great folks here who have helped me so far On this slot revival journey.
I’m working on a 25¢ Jennings Silver Chief and trying to diagnose a very consistent payout problem.
I removed and thoroughly cleaned the payout slides and reassembled them dry. With the payout tube properly filled, these are my repeatable results:
• 3-coin payout = 3 quarters — correct
• 5-coin payout = 5 quarters — correct
• 11-coin payout = 10 quarters — one short
• 13-coin payout = 12 quarters — one short
• 18-coin payout = 17 quarters — one short
I numbered the seven payout slides #1 at the top through #7 at the bottom. By watching them operate, I have determined:
• 3 payout: #6 + #7 retract
• 5 payout: #5 + #6 + #7 retract
• 11 payout: #4 + #5 + #6 + #7 retract
• 13 payout: #3 + #4 + #5 + #6 + #7 retract
• 18 payout: #2 + #3 + #4 + #5 + #6 + #7 retract
Because the shortage first appears when slide #4 comes into play, I removed #4 for inspection.
I discovered that the small metal separator/cutoff tab or spring assembly on this slide has quite a bit of movement. I’m attaching a video showing exactly how it moves.
My questions for anyone familiar with Jennings payout mechanisms:
Is this amount of movement in that tab normal?
Is this the coin separator/cutoff spring that determines where the coin stack separates?
Could excessive looseness or an incorrect resting position here cause the payout to be exactly one coin short?
Does anyone have a known-good 25¢ Jennings 6-coin payout slide (V3-131) that they could photograph from both sides for comparison?
Does anyone have a spare V3-131/6-coin slide they would sell?
I don't want to bend, tighten, peen or otherwise adjust the tab until I know how it is supposed to operate.
Any Jennings-specific experience would be greatly appreciated. I can provide additional photos or videos if needed.
Here is a short video of the #4 slide tab movement.
https://youtu.be/53Iktr9JrZk
Thanks in advance
Mully
Mully911$
Re: Jennings Silver Chief 25¢ – Higher Payouts All One Quart
Postby memphisbigdave » Sun Aug 30, 2026 4:29 am
I think you’re being to analytical about a 75 year old mechanical slot machine. A lot of slots from this era give a range on the payout card for each payout, due to thickness of worn or new coins. I believe you are well within tolerances
memphisbigdave
Postby Swami » Sun Aug 30, 2026 10:11 am
There is nothing wrong with your machine. If you want it to pay correctly on the larger payouts, you will need to only use Older Silver Quarters. They are thinner than modern Clad Quarters. Stack up 18 Silver Quarters and next to it Stack up 18 Clad Quarters, you’ll see the difference immediately.
Swami
Postby sam2002 » Mon Aug 31, 2026 8:59 am
Swami wrote:There is nothing wrong with your machine. If you want it to pay correctly on the larger payouts, you will need to only use Older Silver Quarters. They are thinner than modern Clad Quarters. Stack up 18 Silver Quarters and next to it Stack up 18 Clad Quarters, you’ll see the difference immediately.
True!
Postby Mully911$ » Mon Aug 31, 2026 9:30 am
Gentlemen, I appreciate your knowledgeable responses. When I restore something or work on something, I want it to perform the way it did when it rolled off the assembly line and you’re all telling me that’s the way it rolled off the assembly line, 89 years ago. So I’ll call the payout portion of this functioning. just for knowledge sake does anyone have insight on what the spring tabs underneath the slides are for exactly?
Mully911$
Postby mazzeosa17 » Mon Aug 31, 2026 2:04 pm
Those tabs on the bottom of your payout slides are to keep coins from jamming during payout, to ensure the correct number of coins payout. In other words, to avoid an extra coin from paying out or jamming the slides. At least, that's been my understanding over the years.
mazzeosa17
Postby Mully911$ » Tue Sep 22, 2026 4:06 pm
Hey Swami,
I did as you and others here suggested and managed to round up 18 silver quarters, not an easy feat, Coin places want like $5 a piece for them so it took me a while. The stack height of 18 silver quarters was roughly .95mm less than an 18 stack of modern clad quarters. My results were exactly the same with silver quarters as they are with modern quarters. Three and five coin payouts were correct but 11,13 and 18 pays we're all one quarter short.
Mully911$
