what machine?
what machine?
Postby MikeInMontana » Wed Oct 07, 2015 5:12 pm
Anyone know what this coin mech goes to?
MikeInMontana
Re: what machine?
Postby sam2002 » Wed Oct 07, 2015 7:19 pm
Looks possibly like a digger??
Re: what machine?
Postby MikeInMontana » Thu Oct 08, 2015 9:20 am
It may well be as I once had a digger. This coin tube may go with it then. Mike
MikeInMontana
Re: what machine?
Postby captkid » Thu Oct 08, 2015 3:06 pm
Mike
That's the coin switch/cycle unit for a Exhibit Supply claw machine circ 1930's
It triggers the motor to start through the contacts when closed by dropping coin through the tube - when the motor completes the cycle, the contacts are pulled open by the chain to stop the motor and resets for the next play
Most diggers missing this unit require installation of a relay, actuated by a coin switch to do the very same thing
this assembly is very hard to find - hope you can use it!
captkid
Re: what machine?
Postby MikeInMontana » Thu Oct 08, 2015 9:06 pm
Thanks Captkid,
It was an Exhibit Claw machine that I had. I must have come across an extra coin switch and bought it. My claw machine has been long gone. Is the coin tube part of it also?
MikeInMontana
