high top lighting system
Postby JHSS-1944 » Wed Apr 13, 2016 1:49 am
Hello to all;
Does anyone have a Mills high top with a "factory" lighting system in it ?? I really would like to see what it looks like ,if some one can take the time for photos.
I own a Bell-o-matic (mills) 1958 four -7-crown slot machine, which originally had a lighting system but, has been totally removed. the only information I found is in the parts (via a supplement manual) ;
MLB-8839 = 6 watt lamp (2 used) (lamps No.4 & 5).
MLB-8838 = 4 watt lamp (4 used) ( lamps No. 1-2-3 &6).
MLB-8702-CSP =wiring Assem. (harness less lamps).
MLB-8711 =spacer (2 used) for mtg. coin denominator glass & starter plate assem.
Starter- General electric FS-5 starter.
Ballast- (Robertson transformer Co. 6w-12 ,AMP.60 cycle AC Cat. L-6) ( 4 required with 4 watt lamps.....
Same.... 8w-12.... Cat.L-8 (2 required with 6 watt lamps....
lamp socket- General electric 75 watt 250 volt lamp socket.
And that's all I know. manual image to low quality to see anything.
2 of the lamps light the lower front glass up ; assume one for above the reels , rest ???
Any help would be very appreciated.
Best regards; Jeff H.
