Pick a Buckley lock?
Postby flipper77 » Sun May 08, 2016 2:04 pm
Picked up a decent quarter Buckley but owner had lost the back door key. This has the tubular lock/key like my late Jennings and Ballys. Any one familiar with these - can these be opened by a locksmith and can a new key be made? Looks like the original Buckley lock so hate to drill it out. Flip
flipper77
Re: Pick a Buckley lock?
Postby JHSS-1944 » Sun May 08, 2016 2:30 pm
Hello ;
first these types of locks are much easier to "break into......"
This will sound stupid..... but it may be opened with an ink pen. take a bic type ink pen, take the plastic filler piece off the back end , the use a razor blade and basically cut a cross into it = 1 slit across , 1 slit up and down. so what you have is 4 slits / 4 pieces of plastic. shove the hole pen into the lock & twist it back & forth ( clockwise / counter clock wise) for a bit till it turns. slit depth depends on the mushrooming of the pieces & depth of that lock area.
Then remove the lock , take to lock smith for a new key.
YES , this can work... & works often. this lock should have 8 or 6 pins in it but ,only a few of these pins really do anything.
check the internet for picking these locks.... Very good story on it , doing this method.
A major lock company who backs their locks with a $3,700.00 cash guarantee. had a guy continually opened their locks with a pen (on you tube no less). they had to buy back the locks & redesign a new one.
if you have the "right " type screw drive with removable tips for different screws or hex type head bolts , same method ,just use with out any tip in place. This is also seen in you tube videos , takes seconds to do.
Build a better mouse trap & some one will build a better mouse.
Postby JHSS-1944 » Sun May 08, 2016 2:36 pm
OH , by the way , Chicago lock company "still exists".... can't recall the name of the company who bought them out. they are in South Carolina (Xcomp . = ?????) they still make much of the Chicago lock line up from the past.
Postby flipper77 » Sun May 08, 2016 4:13 pm
Thanks Jeff Will give it a try. Appreciate the suggestion! 8)
flipper77
Postby RameGoom » Sun May 08, 2016 7:58 pm
I use this style lock pick for all 7 pin barrel locks:
Takes about 10 seconds to open an Ace lock.
Postby JHSS-1944 » Sun May 08, 2016 10:41 pm
Ramegoom;
how much do these sell for ? I've seen them in use ,but I've never used.
Postby RameGoom » Mon May 09, 2016 4:51 am
The part I use is a 7 pin, part number TPXA-7 made by Southord. I believe they're available on Amazon for somewhere around $60 or $70.
You set all the pins flush with the end, put a bit of tension on the O ring nut, insert it into the lock and wiggle it a few times. Somehow, the pins find the depth of the tumblers and within a few moments, the lock is open.
And, if you have a key cutting machine for these types of keys, you can use the tool as a key, and make a key for that lock from a blank. Pretty cool operation. They make an 8 pin model, so if you are into re-keying locks, it'd make sense to have both.
Postby JHSS-1944 » Mon May 09, 2016 10:57 am
Thank you for the information !!
I have found way to many Sega & Bally machines with no keys , got lost.
Unfortunately the Sega's have a 10 pin lock = British made ,long out of business.
Postby insertcoinhere » Tue May 10, 2016 6:32 pm
The 10-pin pick is available too (in addition to the 7 and 8 pin already mentioned). I purchased mine from http://www.ukbumpkeys.com/products/south-ord-10-pin-tubular-lock-pick
insertcoinhere
Postby JHSS-1944 » Wed May 11, 2016 8:37 pm
I'll have to look into them.
Thank you for the information.
