ABT pistol disassembly
Mon Jan 09, 2017 9:33 am
by md171
Greetings again,
I need to get to the spring in the barrel and striker etc. I have the crow river diagrams and it looks like the end plug comes out by removing a pin, but I don't want to go tapping too hard on stuff. Can someone guide me along please.
Thanks!!
Re: ABT pistol disassembly
Mon Jan 09, 2017 9:48 am
by jmac
It is a tapered pin and should come out pretty easy from the correct side. A light tap.
If you take the pin guide out of the barrel, you will need to press it out (drill press works good) the pin guide is zinc or pot metal, and a set screw by the coin slot needs to be removed first. When pressing it back, it is a little tedious to line up properly.
Mon Jan 09, 2017 10:04 am
by md171
Got it!! Thanks!!
Tue Jan 24, 2017 7:12 pm
by md171
Another question, how far should the firing pin stick out from the firing pin sleeve when the trigger is pulled? My gun shoots duds or not at all sometimes and the mechanism is working fine. It appears the firing pin isn't hitting the pellet enough to send it out sometimes and when the next tries to load it gets stuck in the lift chamber. I think firing pin might be too short having worn over time. Most times it shoots but weak and inconsistent a significant amount of the time. I've cleaned the loading chamber and barrel but still has this issue.
Wed Mar 08, 2017 10:58 am
by jmac
I have a similar problem with one of my abt guns, inconsistent shooting, I talked with Roger Hilden at Crow River, he is the expert of ABTs. He said to press that part out of the barrel and inspect, and then he usually reams out the end of barrel right where the pellet rests, because sometimes bumps and deformities form there from heavy use. I did that, and tested with new pellets and still has inconsistent shooting, have to take it apart again and figure out why.
Might want to talk with Roger, and maybe try new pellets.
Wed Mar 08, 2017 5:36 pm
by md171
Thanks! I caved and sent it in. Roger straightened the barrel and apparently the firing pin sleeve set screw was stripped out. Thought I had that fixed. Anyway it works now. Thanks again!!
