Poinsettia jackpot problem
Postby Major Kong » Sat Jul 08, 2017 6:11 am
Got this Mills Poinsettia working. I cannot get the jackpot or the reserve to dump. Am I missing something mechanical or have it somehow setup incorrectly. Additionally, there is a small set screw on the top slide that is flat on the top (worn), if this helps any.
Thanks.
Tom
Major Kong
Re: Poinsettia jackpot problem
Postby norabt » Sat Jul 08, 2017 6:25 am
Remove the top casting then cycle the mech to see how the slides and jackpot trip lever interact with the jackpot levers.
norabt
Postby gsx11r » Sat Jul 08, 2017 10:06 am
Hi
I think that the "A" part must to be on back of the "B"part.
Like mine:
For info , your jackpot model are uncommon on Poinsettia. It s more easy to find the other model .
But Don t worry it s original ,and are complet on your machine .
let me know , and if you have other trouble , let me know and I will check on mine !
And PLEASE , remove this screw and use the good one !!
Stephane
gsx11r
Postby Major Kong » Sat Jul 08, 2017 2:46 pm
Thanks!!!
Removed top front piece and watched unit cycle.
Then took another piece of advice, removed a few of those bad screws (referenced above) and slid the bottom plate forward. Everything now works correctly (jackpot and reserve). Special thanks to the forum and those who responded :D
Tom
Major Kong
Postby SLOT DYNASTY » Sun Jul 09, 2017 1:58 am
Glad to see that you figured something out on your own, by moving the bottom plate.
Most people do not realize that something as simple as moving that plate ever-so-slightly,
one way or the other, can solve lever engagement problems. Especially with a jackpot.
