Cast Iron Chrome Bell Restoration
I am just starting the restoration of an original Mills Chrome Bell circa 1938-39. It is original as found and was actually full of silver quarters once I extracted a broken key shank and had a new key cut by Dave Berten.
I am certain I will have many questions because this is only my seventh machine restoration and only my second Mills. The first point of question I have concerns the mechanism bottom. I have two other "Diamond Front" machines that are both post war machines and the bases are cast iron i. e. magnetic. This machine with all its ultra heavy cast iron castings has a base made of what I believe to be phosphor bronze. At first I thought it was just plating to make payout slides smooth in operation but it is solid (non-magnetic) and the color indicates bronze rather than brass. It is heavily patinated over these last 78 years or so and I am not sure if I should restore it to bright bronze finish for not. The how part is easy if desired. I can just have it bead blasted and then clear coated. I want this restoration to be as correct as possible so if on the off chance that Mills actually applied a patina to the casting I sure would not want to change that and over restore the machine.
I will follow the advice of this forums collective experience.
