Puritan Baby Bell Lions mfg Co
Postby Cfroadhog » Fri Dec 28, 2018 8:33 pm
Need to solve a mystery. Need ideas and help. Three wheels, when penny is inserted sometimes all wheels spin next time only one spins next time maybe two spin the center wheel works the least. Seems to work better when done manually.
Cfroadhog
Re: Puritan Baby Bell Lions mfg Co
Postby capt7310 » Sat Dec 29, 2018 5:30 am
I have the same machine and had the same problem when I first got it. The first reel left and the 3rd reel right spin in one direction and the center reel spins in the opposite direction. I used a degreaser and sprayed the shaft on inside of the reels and then used fine oil on each reel shaft and it works perfectly.. Try it... I'm sure you'll get other guys with there thoughts Good Luck
capt7310
Postby Cfroadhog » Sat Dec 29, 2018 2:22 pm
I’ve cleaned all the grease and oil every thing sounds like it slams too hard some times other times not so hard Center wheel spinning the least
Cfroadhog
