Mills base repair/replace
Postby GR14 » Sat Mar 30, 2019 3:07 pm
Hello, I have a Mills Castle Front nickel slot machine that has been in the family for 70+ years. The front 3 or 4 inches of the base is missing. Are bases available, either used or repro? If I end up making one, are there any pitfalls? Thanks!
GR14
Re: Mills base repair/replace
Postby mechanic » Sat Mar 30, 2019 5:31 pm
A picture helps to determine if the base is repairable!
Postby GR14 » Sun Mar 31, 2019 10:24 am
GR14
Postby radiorich123 » Sun Mar 31, 2019 12:23 pm
It can be repaired no problem. You need to find aged wood that the base was made of so it matches the old one. Yours looks original from the photos.
