Mills 10 cent slot machine restoration
Postby rdub » Mon Mar 30, 2020 1:45 pm
I have an old family slot machine that doesn't work. It is a Mills slot machine, made out of wood and it takes dimes. That's the extent of my knowledge. I live in San Antonio Texas. Does anyone know where I could get some help? Thanks, Rob
rdub
Re: Mills 10 cent slot machine restoration
Postby MJFHouston » Mon Mar 30, 2020 2:44 pm
Rob,
Try and see if you can post a picture so I can see what you have I'm in the Houston area and then we can go from there
MJFHouston
Postby rdub » Mon Mar 30, 2020 3:42 pm
I believe it is attached now. Thanks, let me know.
rdub
Postby kentdun » Mon Mar 30, 2020 4:23 pm
It is a Mills Castle Front. An earlier one because of the paper award card. Do you have the key
What doesn't work on it? If you take off tne back and gently try moving parts you can sometimes fix a jam.
Pulling the mechanism is not difficult. I think there may be videos on YouTube about clearing a jam.
Classic machine and looks to be in nice shape.
kentdun
Postby mechanic » Mon Mar 30, 2020 5:24 pm
If this is original it should have a wire on the bottom left rear of the mech between 5 springs with a 90* bend on it. Push the wire in toward the springs and pull the handle slowly, if it kicks the reels it may be ok. If not there could be some other jam.
Postby rdub » Mon Mar 30, 2020 6:48 pm
Thank you for the help! I don't have a key, so I can't open the back. Simple locksmith job?
rdub
Postby kentdun » Mon Mar 30, 2020 7:01 pm
Very hard lock to pick.
Do not drill the lock. They are not cheap to replace. Others on this site know ways to the back.
Hopefully they will chime in.
kentdun
