Removing plunger end of vacuum pump
Postby Walter Newton » Sun Jan 24, 2021 1:55 pm
I need to replace the leather pad (or revive it with some oil) in a Groetchen Imp vacuum pump.
How do you get the plunger end off of the cylinder?
Is the collar simply pressure fitted or threaded?
Or does anyone have a full working pump unit for sale, which would obviously be easier.
Thanks for your help in advance.
Walter Newton
