Mills 2/5 payout slides
Postby sam2002 » Tue Feb 02, 2021 8:49 pm
Working on a Mills high top, 2/5 payout, all the payouts work except the 2 largest, 3 bells supposed to be 18 payout but gives 17 , same scenario on the jackpot slide pay supposed to be 20 but pays 19 via the coin slides. All of the other payouts are as they should be. My question is, is there an adjustment on the tang I see on one of the slides? Or did someone swap out these with a narrower upper slide?
Thanks for any comments.
Re: Mills 2/5 payout slides
Postby kentdun » Tue Feb 02, 2021 9:05 pm
Try using older coins that are worn and a little thinner.
This is the reason some payout cards gave a range of payouts.
kentdun
Postby sam2002 » Wed Feb 03, 2021 9:12 am
kentdun wrote:Try using older coins that are worn and a little thinner.
Thanks will give this a try!
