SLIDES mills
SLIDES mills
Postby jumpinjaxsisfun » Tue Mar 02, 2021 6:17 pm
Hi Guys, my question, I have a 1929 poinsetter. does anyone know the sequence of them: mine from bottom to top (6) in all,
tab,tab, marked 1 dot,2 dot,3 dot, blank. Is this the right order???, thanks in advance, vin
jumpinjaxsisfun
Re: SLIDES mills
Postby oldslotman » Tue Mar 02, 2021 6:44 pm
Two small 2 coin slides go on the bottom. The other 4 slides should all be 4 coin slides.
Re: SLIDES mills
Postby jumpinjaxsisfun » Wed Mar 03, 2021 7:39 am
So what your saying is, bottom 2 move together and the other 4 move together?
jumpinjaxsisfun
Re: SLIDES mills
Postby oldslotman » Wed Mar 03, 2021 9:11 am
The bottom two give you the 2 and 4 coin payouts. The others add 4 coins to give you the 8,12, 16, 20 payouts.
Re: SLIDES mills
Postby jumpinjaxsisfun » Wed Mar 03, 2021 3:50 pm
thanks oldslot, What I am trying to find out is If the slide in my machine are in the correct order. My machine is not paying out and I am looking for every angle to see why not. I would like to know from bottom to top what slide in sequence in position. in the other post I have listed my order is that correct? thank you again. vin
jumpinjaxsisfun
Re: SLIDES mills
Postby oldslotman » Wed Mar 03, 2021 4:16 pm
The two thin slides go on the bottom. The other 4 slides should be the same size and go on to of the other two thin slides.
Re: SLIDES mills
Postby 5$ed » Wed Mar 03, 2021 5:11 pm
Sounds like you have more issues other than slide orientation.
5$ed
Re: SLIDES mills
Postby jumpinjaxsisfun » Wed Mar 03, 2021 9:18 pm
Thank you guys, I have to look further I guess. Vin
jumpinjaxsisfun
Re: SLIDES mills
Postby collector1 » Mon Mar 22, 2021 7:54 pm
Have you checked the safety slide on the bottom and then check in the front if the little piece of metal is sticking up and is intact because if broken off it will not allow your win to go thru the hole in the bottom. post a picture of the bottom slide and I can look at it.
collector1
