So fill me in on how a Mills QT - 5 cent Chevron in this case - fills its double jackpot.
Right now it is only routing coin to the left JP (when viewed from the front). Is this correct....does it fills the left one up first and then do the right one? Or should it be alternating and is not doing that for some reason?
If it is suppose to alternate sides on each coin please enlighten me on what mechanism makes it switch from side to side.
Thanks!
