Page 1 of 2
Mills Chevron QT Parts WANTED
PostPosted: Mon Jan 02, 2023 12:31 pm
by gvt1911
Picked up a Mills QT "Chevron" 1 cent model that needs a lot of TLC... From first glance, I am in need of a wood base (original is rotted) , back door with lock, replacement front lock, reel strips, award card and other misc. items that are broke or missing... I have yet to really get into the mech as of yet... Will need handle plated also...Any leads will be appreciated..
Thanks , Joe
Re: Mills Chevron QT Parts WANTED
PostPosted: Mon Jan 02, 2023 1:16 pm
by Rsossa31358
Have repro back doors. Some other original parts
PostPosted: Mon Jan 02, 2023 2:51 pm
by rtmccurdy
I have a nice close to original repro front lock. Rick Frink has award cards and reel strips. Spring kit available on eBay from Dave Berten. Message me for lock info. Thanks, Robert McCurdy (or email: rmccurdy@osprey.net)
PostPosted: Wed Jan 04, 2023 12:46 pm
by gvt1911
OK,
Found back door, had locks , reel strips and award card in parts box... Also found local who is going to build new cabinet ... :D
Now I have to get into it and see what parts are needed... Thanks to all..
PostPosted: Tue Jan 24, 2023 9:42 am
by gvt1911
Getting into machine and right away I need the coin shute? also this screw below shute going thru is only half. ? Any help??
Thanks!!!
PostPosted: Tue Jan 24, 2023 12:17 pm
by gvt1911
OK,
I need what I believe is called a "throw-out Chute" ...Also I am curious as to this screw? Seems that I need to braze the bushing in properly and then make a screw that goes thru to the other side of this "flipper"..??? Can anyone advise how long this screw should be or have an original???
PostPosted: Tue Jan 24, 2023 1:43 pm
by gvt1911
Help,
I need this screw and throwout chute with the small retainer bracket...Any leads?
PostPosted: Tue Jan 24, 2023 4:57 pm
by rtmccurdy
That is a check pusher screw and it is difficult to locate (as well as the check diverter). Many operators removed this part and the check diverter (located in front of the coin tube) since the machine was usually used only with coins. I am having some screws custom made currently and will let you know when they are finished. The other part is the reject coin chute and I will have to look through some boxes in storage and see if I have an extra. I also do QT repairs if you don't want to tackle a specific part of the slot. Robert McCurdy
PostPosted: Wed Jan 25, 2023 11:41 am
by sam2002
I’ve recently acquired a Mills 1 cent QT missing the check separator as well. Can’t help it but would love to find these parts as well, shoot if I even find these parts then I’d have to find a load of penny checks to go with it.. ohh well…
Sorry for hijacking on your post but couldn’t help but find a new found fascination for what I call my little 6 clicker!
Good luck and hope you find your parts!
PostPosted: Tue Jan 31, 2023 6:34 am
by gvt1911
Moving right along on this rebuild. I made the pusher screw and the throw out chute. Now I could REALLY use those photos from the book. I purchased the book on a thumb drive, but the illustrations are terrible. I am hoping that someone that has the book could possibly make good photo copies of all the important detailed illustrations for a small fee. This would help me out a lot. :!:
