Bally 1981 door lock
Postby filofilato » Tue Nov 14, 2023 1:28 am
Good morning
I have to restore my first slot machine
It's a 1982 bally (I think)
on the side there is a label with the writing E series
and a stamped date 10 1 82.
My first problem is opening the door which is locked.
Unfortunately the lock has previously been ruined by trying to drill it and I can't try with a lock pick.
Can anyone suggest me the best strategy?
If I act sideways cutting with a disc can I get a result? If so where should I cut?
I can't find a video or internal photos to understand where I need to cut.
Thanks in advance .
filofilato
Re: Bally 1981 door lock
Postby scottie » Tue Nov 14, 2023 4:52 am
Hi
Just keep drilling it and work your way up with a bigger drill bit,,,,it will fall apart and then you can replace it with a new lock
Scottie
scottie
Postby filofilato » Tue Dec 12, 2023 12:35 pm
Thank you Scottie.
I did what you said , it was a little difficult but at the end now the door is open and i can start with the restoration.
Tahnk you so much
filofilato
