Caille pump
Caille pump
Postby memphisbigdave » Thu Dec 14, 2023 5:44 am
Has anyone done, or can anyone do, a pictorial rebuild of a Caille slot machine pump. I’m hesitant to dive into it as I have no idea what’s in there! I’ve read people put a rubber washer under the lid to stop leaking. Where does it go, is it a special material, do you use Dot 3 brake fluid?. I’m sure lots of people would appreciate photos
TIA
memphisbigdave
Re: Caille pump
Postby just frank slots » Thu Dec 14, 2023 6:07 am
I have the same problem... Any information and "MANY" pictures will be helpful...
just frank slots
Re: Caille pump
Postby wallruss001 » Thu Dec 14, 2023 10:15 am
If you search on the Repair/Restoration board for Caille Regulator, there is plenty of info, some pictures of internal parts and fluid to use
wallruss001
Re: Caille pump
Postby wallruss001 » Thu Dec 14, 2023 10:20 am
Follow link to Caille silent sphinx help needed
wallruss001
Re: Caille pump
Postby just frank slots » Thu Dec 14, 2023 12:15 pm
Thanks... I'm not good at computers but I think I found it... Here's a link... Thanks for the advice!
https://www.flipjuke.fr/regulateur-hydr ... 03436.html
just frank slots
Re: Caille pump
Postby wallruss001 » Thu Dec 14, 2023 12:56 pm
I've found removing the adjusting "needle-valve" and operating the regulator will pump out the old "fluid"which is nasty, then run top quality brake fluid through it to clean more. clean the valve and seat with soft wire brush, like gun cleaning tool. Refill, purge air out until you are full, I used a squeeze condiment bottle with tapered end, replace valve and cap.
wallruss001
Re: Caille pump
Postby memphisbigdave » Thu Dec 14, 2023 2:32 pm
Well that link is great but it’s not in English
memphisbigdave
Re: Caille pump
Postby just frank slots » Thu Dec 14, 2023 3:12 pm
It can be translated from French to English with a push of a button.
just frank slots
Re: Caille pump
Postby memphisbigdave » Thu Dec 14, 2023 3:55 pm
Not sure how
memphisbigdave
